I've seen many people talk about removing the spacers under the stem to lower it on the Trance X, but I haven't seen a discussion about it. First off, any theories on why Giant puts the stem so high? Secondly, when/if you lower the stem, how low do you guys like it. Is there any rule of thumb on where it should be in relation to the seat, and why? I understand lower will weight the front more, and vice versa, but again is this just a matter of personal preference or based on some rule of thumb?
As far as I'm concerned, when I got my Medium X1 it came with a 100mm stem. I felt too stretched out, so I changed to a 90, which made things a ton better, especially on steep drops. This is with the stem being high. I'm going to play around with lowering it, but will going lower make the cockpit more cramped, like I'll need to go back to the 100? My thinking is it won't, when I picture in my head the effect should be to move the bar slightly further, but what are your experiences. Stay with the same stem for the first try or go longer?
