Last 2 items I have to buy for my dream bike. What do I want? I'm running a riser bar now and like it.
The Syntace Duraflite carbon 580mm with a 9 degree sweep 118 grams I just sold one but for a flat bar the 9 degree sweep is nice compared to 3 or 6 degrees most flat barsJersey said:you want a Syntace F99 stem (99g @ 105mm) with an Easton monkeylite SL bar (135g)
stem can be had at http://www.light-bikes.com
What's wrong with the 105? I've got 3 in that length. Can't hardly tell the difference between them and a 110 and on one bike it's more appropriate.cogswell23 said:But, y'know, if you ride a 90mm or 120mm stem, and like narrower bars, the F99 is a hot setup too.
My $.02
There are still many, many options for 25.4mm clamp diameters.4212darren said:I've got an Easton EC 90 flat that I took off my NRS and a Monkeylite that I put on so I could just swap and buy a stem. It looks like all the new stuff is 31.8. Is that a solution to something that wasn't a problem?
Nothing's "wrong" with the 105mm, unless its not the right size for you. You say that on one of your bikes it's more appropriate, and that on the others you can't tell much of a difference.Asahi said:What's wrong with the 105? I've got 3 in that length. Can't hardly tell the difference between them and a 110 and on one bike it's more appropriate.
