Flat bars made a comeback on the DH bikes (lowest possible center of gravity when you hold the bars low and you can tuck in lower) and on the 29ers, particularly for short people and/or long travel 29ers. The bigger wheel forces everything up so removing the rise out of a bar helps bring the grips to the saddle level or below.eastman said:Gents, I'm looking for a new stem and bar. Please let me know if you have any recommendations. This is for XC riding. Seems like I'm seeing more flat bars and less risers. Any reason for this?
I have a Turner o2, ride mosty XC. Thompson stem, 110, with a 15 degree rise (Ugly). Flat Easton Bar. Since I'm not buying a new frame, I'm pretty open on budget.SSINGA said:Bike? Current setup? Budget?
Hard to go wrong with a Thomson stem regardless of the above info.
I'd say get a shorter stem, zero rise and a OS riser bar.eastman said:I have a Turner o2, ride mosty XC. Thompson stem, 110, with a 15 degree rise (Ugly). Flat Easton Bar. Since I'm not buying a new frame, I'm pretty open on budget.
That's what I put on my latest build a couple of months ago, bargain price too if you get one from Chainlove or DeptofGoods.MK_ said:On SSINGA's suggestion of the Thomson, I've recently became a big fan of the Sunline stems. Very stiff, significantly lighter than Thomson and a tad cheaper.
_MK
Spectacular e-bike fit recommendation based on all the dimensions that have been provided (not just at _MK, at thread in general).MK_ said:I'd say get a shorter stem, zero rise and a OS riser bar.
_MK
Thanks. Zero rise + riser = 15deg rise stem plus flat bar.skunkty14 said:Spectacular e-bike fit recommendation
Meh, internet tongue-in-check fail on my part I guess. No worse than garden variety Homer, just one of several types of garden variety.SSINGA said:Why all the hate Skunk? So, if you have wide bars and a short stem you are now a higher level poseur than just the garden variety Turner poseur?
Just more garden variety Homer Humer!skunkty14 said:Meh, internet tongue-in-check fail on my part I guess. No worse than garden variety Homer, just one of several types of garden variety.
Carry on....:thumbsup:
Thanks MK!MK_ said:Thanks. Zero rise + riser = 15deg rise stem plus flat bar.
Shorter stem, because, that's just better.
_MK
Maybe go cheap at first, and try a few different setups until it feels right. If your frame is somewhat of a decent fit, most likely you end up at 80-100mm stem length for XC, and as short as 50mm for core shredding.eastman said:I have a Turner o2, ride mosty XC. Thompson stem, 110, with a 15 degree rise (Ugly). Flat Easton Bar. Since I'm not buying a new frame, I'm pretty open on budget.
