Steerer Tube Length on Fisher 29er - Sz Large
859 Views 2 Replies 2 Participants Last post by  schwendy2
Looking to build up my 09 paragon and am trying to get a fox f29 fork off ebay...anyone know how long the stock steerer tube is on a fisher 29er? I don't want to get anything too short. I have looked through old threads unsuccessfully. Thanks!
1 - 3 of 3 Posts
Figure out how long your headtube is and find out the stack height on the stem you'll be using(add them together). Then add like 40 mm and that should give you enough of a range for adjustment with the stem. I tend to leave my steerer tube longer than normal for resale or if I decide to switch frames, there will be plenty of steerer tube. I run most of my spacers on top instead of below the stem. Both of mine are at 8 7/8 inches(one 26 & one 29).
The length of the stock steerer tube is not something you need to go by. They do tend to come a little long, so you have room for adjustments. You'll generally find used forks cut rather short - mistake IME.
Great...thanks for the methodology...seems perfect
1 - 3 of 3 Posts
