1 - 2 of 2 Posts
Can I Borrow Some Style?
I am wondering how to measure the steerer tube length for my 03' Bullit. Do you measure from the bottom cup all the way up to the top of the stem? Thanks, Or if you already know it please let me know
just remember measure twice, cut once. run the steerer tube through the headtube making sure you have all the piece of the headset in place. add your necessary spacers (completely up to you as far as how high you want your stem), throw in the stem, make sure everything is relatively tight. mark the steerer tube at this point. from here, you'll want to measure 3mm down and cut there. this 3mm allows for the steerer tube to be pulled up by the top cap, allowing everything to be tight and eliminating play. hope this helps.
1 - 2 of 2 Posts
