1 - 4 of 4 Posts
OK, I just can't seem to find a Manitou Minute Expert or Pro anywhere.
So I need another recommendation.
I want a 100mm travel fork, with 1 1/8 steerer.
Strictly for XC riding.
In the priority dept, it goes like this:
- handling, stiffness, comfort, weight.
Preferably under $400?
Links to good deals will also be appreciated.
Thanks all,
Lenny
I've been trying to do the same in 120mm. From what I've been seeing the on sale 2013 stuff has already been bought up. Anything 2014 that's worth buying looks like its $500+. So craig's list and ebay are probably going to be the way to go.
X-Fusion velvet is a nice fork. I don't know if the new one has a 1 1/8 steerer or not, but the 2012 one has. It's well priced, stiff, you can set the travel internally if you want, and can be used as a 27.5 fork if you use the travel limiter specer (-10mm travel)
Or just get a RS Reba. €200 if you don't mind pushloc or poplock remote versions. €300 if you do.
Bike24 - Rock Shox Reba RL Solo Air Fork 100mm black 2014
ROCKSHOX 2013 Reba RL 26" 100mm Solo air Axle 9mm Disc 1 1/8 PUSHLOCK Black (00.4018.298.012) RCZ Bike Shop
1 - 4 of 4 Posts
