I have a new set of Stan's NoTubes ZTR 355 rims. I bought rim strips and also just valve stems. I am using STan's thin yellow tape. According to Stan, I should only have to use the yellow tape and the valve stem (no rim strip). This saves 38g a tire and makes mounting tires way easier (easier to get bead into drop channel).
My front taped up and sealed up well. My rear tire won't seal. The valve stem is leaking. I have watched Stan's video on how to tape a wheel several times. I can't make out what he does when he goes through the tape with the rat tail file. Am I supposed to let the valve stem stopper seat against yellow tape or should I cut the yellow tape hole big enough to allow the valve stem stopper seat against the actual aluminum rim?
Thanks for any advice you can give.
Robo
Robo
