1 - 8 of 8 Posts
Anyone tried using Stans 160/140 aluminum rotors with the new '07 XTR disc brakes? I'd like to hear your experiences - performance and set-up/install. This combo would work out to be an additional 95g net savings for me, even after factoring in the necessary DT Swiss CL adapters....Thanks!
I can't answer your question but you don't need adapters if you get a regular 6 bolt rotor, the calipers don't require CL.
Discussion Starter · #4 ·
4212darren said:
...you don't need adapters if you get a regular 6 bolt rotor, the calipers don't require CL.
Stan's rotors only come in 6-bolt, and since I have CL hubs, an adapter is required to attached the rotor to the hub
I love Pisgah
I don't think the 140mm are avail from Stans anymore. I may be wrong tho..
1 - 8 of 8 Posts
