I know people have had some good and bad experiences with sealant and I'm all about not using tubes if I can help it. I have been using Stan's Notubes sealant for years and wanted to try something else so I bought the Bontrager Superjuice. The dealer told me he didn't feel it worked as well as Stan's but I wanted to try it anyway. It's very pricey at $16.99 for 8 oz while I can get Stan's 32 oz bottle for around $20. The dealer's basic gist was that the Superjuice only sealed tiny thorn holes well and cost way more than Stan's which sealed stuff better. He did not carry any Stan's- just Superjuice and a generic one.
Superjuice is clean and easy to work with. It looks good enough to drink with Vodka. It seals small holes okay but anything more than a thin thorn and it keep oozing and bubbling out and takes a long time to seal. It also evaporates very quickly when left out with a similar weight of Stan's sealant. Almost all the Stan's sealant is still there while the Superjuice has significantly evaporated in 24 hours (pretty dry here in Colorado). I have not tried the evaporation test in a tire but will do that next. I cannot imagine that it will last longer than Stan's given my open air test in two tires. The quick evaporation was a bit too quick. I don't know what the liquid is made out of but it dries fast. My hopes were dashed since I thought it would outlast Stan's stuff. I now have one type of sealant in each tire and will recheck the quantity in a week.
I have heard that this is a rebadged sealant from some other industry. It simply does not work as well as Stan's though it does quickly form a slick seal around the beads that then dries well and holds air properly. That is one thing it does quicker than Stan's sealant. That advantage is not meaningful to me because Stan's sealant does the same thing in a few more minutes. I used tubeless-ready, tubeless, and two regular Maxxis Minions (may as well be tubeless- they are completely non-porous). The Minions do not leak sealant at the sidewalls or anywhere else. At close to 850 grams, they better have a thick non-Kenda casing.
Superjuice is not for converting tires and will do okay as a sealant but a fat thorn hole may not be sealed at all. It will keep oozing and bubbling regardless of how fast you spin the tire. The Stan's stuff will shoot out for a second and then seal the hole completely.
Sorry for no pics- I toook a ton the best I could but my antiquated Smartmedia card decided to only give back gray squares instead of pictures. Video clips would be more effective anyway.
Next time I have some time to kill, I'll try Slime and the generic (A-I?) sealant carried by the local dealer who sold me the Superjuice. I also have the Geax Pitstop foam-like sealant now.
I used three different nails for my test- two skinny ones from my picture hanger kit and one thicker one I found on my driveway crack. I also used a thorn I found. It starts out skinny and sharp but get much wider and thicker at the base and was very strong. I punctured the tread (between knobs) and the sidewalls. I eventually broke the thorn tip off and will have to find a replacement. No, I'm not using a goathead- I can see bad things happening.
If you have sealant info when comparing two or more, post up as well.
