1 - 11 of 11 Posts
What do you guys think? I'm planning to change the rims of my titus el guapo to something more heavy duty.. my current rims are dt swiss XR4.1d which are light... Which rim is better for All mountain - light freeride, dowhill? I like the stans ztr flow because it is light but I'm not sure if it's durable enough... hope you guys can help me :thumbsup: tnx!!
I Void Waranties
from what ive heard is that dt is cheese. Im using the ztr on some 2.3 panaracer 29's and its just slightly of...that being said its been on a hardtail that has seen lots of roots some rocks and small drops. Its even seen a few rounds around the jump track. I would class them as an solid trail wheel. Go for it...
I have a set of 5.1's and a set of Stans arch rims and I would get the DT rims over the stans, I don't weigh that much (185 lbs ) with gear and ride pretty smooth with Stans rims howevere they are a lot weaker then I expected. I have the Dt,s on my nomad and do everything from xc to freeride on them with out a complaint or them going untrue.
Not sure if you can really compare the ZTR arch to the 500's/5.1's, I think the arch is similar to the 4.1's/400's
I have ztr flows and they are good, I like the profile of the tyre on this rim and the fact that its tubeless ready so potential to add an extra dimension to your wheels and the feel of them.
I don't think you can go wrong with either as they are both nice rims, what made me go for the ztr is the tubeless aspect and on a more vain point they look better than the dt's.
ya you are right about the comparison I also own a set of 4.1s and they seem stronger then the Arch, I should have said that in the begining. The 5.1s are holding up to big drops and out of the two now I would only go with the 5.1 or a mavic wheel.
The OP has said light freeriding and since I bought the Arch because it said they were for " aggresive cross country" on their website and would not use them for anything but cross countryI am guessing thier " super d ect " for the flow is an overstatement also.
The reason I am saying this is I put the arch out of true on a g-out which was on a hiking trail. I just have not been impressed with the Stans like I thought I would.
I think your right about the ztr arch most of the description sounds like marketing blurb in order to maximise coverage across different riders and disciplines.
I haven't had enough time on my ztr flows to stand behind them 100% but I just loved the idea of a tubeless set up. The 5.1's always seem to get good reviews and are the base line rim to judge others by which is never a bad thing.
Regarding abuse of the flow's, ride monkey downhill team are riding flows on hope 2's
http://www.ridemonkey.com/forums/showthread.php?t=214810
Bottom line a well built set of wheels on either rims will stand up to most abuse from a trail rider including jumps, drops, rock gardens etc.
Banned
I can only speak for the Flow's and they hold up great and they are a very easy tubeless set-up. I'm running them on an agressive all-mtn set-up and I've had no flats, no bent or untrue rims - basically worry-free.All of my tires seal up with a floor pump, the beads pop and set at about 15psi and I normally run about 28psi with no worries!!
Vaginatarian
Ive been using the flows for over a year with I9 hubs and spokes
drops 3-4' knarly off camber roots and babyheads . Plus I weigh 220 without gear
wheels are straight and true as the day I bought them I would give them 5 stars
MTBR Member
Stan's rims are only as good as their builder. Who built yours?
OP, you can't go wrong with either. The ease of tubeless set up w/ Flows, made the decision for me.
1 - 11 of 11 Posts
