Are you talking about the rubber rim strip?
I have mine set up with stans yellow tape. You want to get it all the way from edge to edge inside the rim for proper sealing. Being they don't make yellow tape wide enough it takes two goes around, one for each "side" so to speak. Right over the bead lock ridges.
Works.
With looser tires I often use a layer of electrical tape on top of this. This isn't really durable but it will last a mounting or two. Makes hand inflation sooo much easier and also locks the tire on better (tighter). This works on Stans rims too. I don't have a compressor, just a pedros floor pump.
Just did a snow ride with 17-18 psi front (ralph 2.4) and rear (xdx tlr) and no burping even with sliding around. Ralph mounted up with yellow+electrical tape and xdx with yellow only.
Dunno about the rubber rim strips. The Flow strip MIGHT work. Dunno.
Works.
