Total noob question, but here goes...
I'm new to tubeless and just received a Hope Hoops / Flow wheelset. Wheels came with rim strip that I'm pretty sure is not tubeless compatible as it appears to be cloth, is narrow sitting only in the valley. The inner rim surfaces have a few pairs of holes (looks like very small drillings) set wide, directly across from each other on each side of the rim strip/valley.
Is the legit tubeless rim strip supposed to cover these little holes?
I plan to gorilla tape it and use cut out valves, need to know how wide it should be.
Helps is much appreciated...
