Would it work?
Yep. Stan's or any of the other tubeless sealants work well in tubes as wellandresmuro said:Would it work?
Not necessarily- I've used Cafe Latex in 2 tubes, and it does squat. The second tube was under controlled testing (sitting at home and doing tests with pins) and the sealant completely failed to work.boomn said:Yep. Stan's or any of the other tubeless sealants work well in tubes as well
this stinks, I was just getting read to buy some of this brandwomble said:Not necessarily- I've used Cafe Latex in 2 tubes, and it does squat. The second tube was under controlled testing (sitting at home and doing tests with pins) and the sealant completely failed to work.
I see ghettos under your post. Is that what you use as your sealant?mtnbiker72 said:It will work but it will dry up...there are better alternatives that do not dry up
I was going to use this brand...womble said:Not necessarily- I've used Cafe Latex in 2 tubes, and it does squat. The second tube was under controlled testing (sitting at home and doing tests with pins) and the sealant completely failed to work.
Well, I triedtrying to get CL to seal in two tubes. Once on a ride, once when I was testing at home. I did everything I could think of- kept spinning the wheel, positioned the pinhole at different positions, kept adding air. Tried the tue in a tyre, tried the tube outside the tyre. Nothing worked- the CL just sprayed or dribbled out.mx_599 said:this stinks, I was just getting read to buy some of this brand
any chance something else was going on besides it simply not working?
but wouldn't there be less evaporation and longer life in a tube? or not really?Squash said:similar type sealants designed for tubeless conversion use do not work well in tubes! The reason being is they have a high volatility rate, i.e. the liquids that suspend the latex and other components evaporate quickly. This is to help seal a standard tire for tubeless use, and to quickly seal punctures etc. The high evaporation rate of the liquid components requires that the sealant be replenished on a regular basis and is the reason that after a few months you find a wad of congealed latex in the tire when you open it up to add more sealant.
The problem arises from this little ball of congealed sealant. A tube can not be opened up and the congealed latex removed, which is a MUST with these sealants. It's part of the recomended maintenance of a tubeless conversion set up like Stans. Eventually you'd end up with a tube full of little koosh balls (or one big koosh ball). That and Stans really doesn't seal tube puncutures very well. But then it's not designed to.
As the others have noted, something like Slime or other thicker sealants that have a much longer life span are a better choice for tubed set ups. The bottom line is, Stans or other "tubeless conversion: sealants simply aren't designed to be used in tubes. So they don't work well (if at all) in a tubed set up. Find and use a sealant that is specifically recommended for use in tubes. You'll get much better results.
Good Dirt
Yep, I have used it in a pinch. But for long term ease of use the slime is better in tubes.Squash said:The problem arises from this little ball of congealed sealant. A tube can not be opened up and the congealed latex removed, which is a MUST with these sealants. It's part of the recomended maintenance of a tubeless conversion set up like Stans. Eventually you'd end up with a tube full of little koosh balls (or one big koosh ball). That and Stans really doesn't seal tube puncutures very well. But then it's not designed to.
I use my own homebrew formulaireland57 said:I see ghettos under your post. Is that what you use as your sealant?
Can someone tell me what "I see ghettos under your post" means????I see ghettos under your post. Is that what you use as your sealant?
+1Can someone tell me what "I see ghettos under your post" means????
