Cloxxki said:Do wire bead IRC's actually exist? I've never seen them anywhere yet....
I've been running Stans with IRC Notos (kevlar bead) on Bonti-Race Lites for a few years now with zero flats or other problems except that my tires are worn out right now. Also running Stans with IRC Mythos (kevlar bead)on Velocity Aerohead rims for over a year and again have had no flats or other problems. I typically run 28-36 psi (depending on the rocks). I think it's always a risk to use the tubeless kits since the tires and rims are not meant to be tubeless but I also think that there are tire/rim combos that work well together and ones that do not. I like tubeless in the thorn hell I live in and if it were not for the billions of thorns here I would run tubes. I do run tubes in 3 other wheelsets but every ride I can count on at least one flat.toddre said:What tires are you folks using with Stan's?
I know not to use wtb and Bonti's and I've tried Klaws with Stan's... anything else?
