Use soapy water if you want. It is not needed to install UST tires with sealant.Dan Gerous said:
Install the tire and inflate.
Deflate an pop one bead loose enough to pour in the sealant.
Reset bead and inflate.
Use soapy water if you want. It is not needed to install UST tires with sealant.Dan Gerous said:I'm getting ready to put some Stan's for the first time. I have a real tubeless setup (Mavic XM819 and Hutchinson Tubeless Light tires) so I'm just using it because I just hate getting flats (who doesn't?). My question is: when I soap the bead-rim interface, there is surely some soapy water going in the tire, will it hurt the sealant's power or should I avoid using soapy water? Tires are new if that matters.
Might be a stupid question but I just want to make sure I do it the right way.
Just pop one bead and pour in a scoop or two.Dan Gerous said:Thanks guys, I decided to mount the tire without Stan's first, to make sure it mounts okay, I don't have much experience so that's a practice (it was very easy). I used soapy water but not much, should I completely dismount the tire and dry everything before I put the sealant or should I just pop off one part of the tire to put in a scoop and re-inflate?
...and just enough to get the sealant in the tire.Mike B. said:Just pop one bead...
