Well dudes,
Today I got my stans no tubes kit. I have been interested in reading peoples stories but most seem to be bashing stans. I have spent some time researching the net on stans and I felt pretty confident that I could handle the task of installing and maintaining stans. The installation is pretty straight forward and the instructions are detailed. The no tubes web site has some good tips.
My rims are mavic 717's and I went with kenda nevegal 2.5 and 2.35 standard tube tires. The front tire is used and in good condition. The 2.35 rear is brand new. I removed the original spoke tape and applied the included stans tape which is thinner and narrower than the velo cloth spoke tape I had. I mixed a bucket of dish soap and water and made sure it was extra sudsy. The rim tape slips on very easily, so easily I was skeptical I did it right! It went into place very nicely. 2 important things to remember with narrow rims....Use soap and water to install the rim strip and use the stans spoke tape. It is also very important to drill the inner stem hole to 3/8" diameter. I did not have a drill so I used my dremel very carefully. I used lots of soap bubbles on the bead of the tire but made sure not to get much water in the rim. This is very important as well. My first try at sealing the bead without the sealant and not as much suds was very frustrating. It did not work and I was cursing stan. Then I used a whole bunch of soap and got the bubbles to be real thick and creamy, I applied the suds to the bead and it aired right up with a floor pump! I was in amazement. I did not expect it to air up so easily. The nevegals are by no means snug around the rim. After I got the hang of it I poured in the sealant and did what the instructions say to seal the tire. The only problem I had was this little tiny pin hole in the sidewall that is not sealing right away.
I will post more later after I get a few rides in. So far the initial set up impression was good. It will seal and inflate as long as you listen to the directions. Every little detail in the instructions is important... I found out the hard way. I hope this will be useful to someone.
