NOTE TO ALL TUBELESS USERS: I've experimented with every 29" tire available with the exception of the Conti Vapor and IRC tires are the only ones with a strong enough bead. The WTB wire and kevlar are terrible, the Kendas lasted a while, the Notos until they wore out, and my Mythos are rockin' out now. I would highly reccommeng the Mythos for tubeless users.[/QUOTE]
I'm running Notos and Mythos (front) on Ritchey rims with Stan's strip. Man, the beads were scary loose, but so far, so good. I'm running about 30 psi. What pressure are you running and have you had any cut sidewalls yet? On my 26-er, I cut a sidewall on a Kenda Karma Pro (which was sweet untill the screwed sidewall), in the first go in a race (The Ultra-100). Stan claims that a lower pressure will solve that problem, but I'm already feeling the rim in rocky terrain. Any thoughts?
Thanks! Fred
