Forget standover....
ttt said:
I was looking at the Marin and the Kona website. I noticed that full suspension xc/trail bikes have higher standover height than their hardtail of the same size. The longer the travel (for those adjustable) the higher the standover.
Does that mean that if I get a full suspension bike, I have to get a size smaller compared to the hardtail equivalent to maintian a good standover clearance?
Standover is not an acurate sizing method for mountain bikes at all. In addition, for get the 'inch' sizing as well. I have a 16" k2 Razorback and a 19.5" Giant Yukon that are virtually the same size. Same whelebase, same virtual Top Tube length. Go figure.
You will have better luck going by Small/Medium/Large. Both of the bikes I mentioned here are Mediums, and I'm 5'10" with a 32 inseam and longer than average reach... and I like my bikes a tad on the cramped side.
The important part to measure on a mountain bike is reach, which is the TT (or virtual TT) measurement, but in reality, that can vary as well, depending on the frame design.
The more travel a bike has, the more standover it will need to have, because the suspension has to travel somewhere, usually down. If you made a 6" travle bike the same height as a rigid bike, the chainrings would nearly bash into the ground when landing big hits and you would be striking pedals on stuff all over the place.
The best sizing method is to go ride the goofy things and see if they fit.
