Most riders criticize the fact that I like to stand when going up big hills, but I always seem to be able to get further up the hill when I stand vs. sit. Since I won't be giving up this habit anytime soon (whether on singlespeed or geared bike), I was wondering if anyone had any tips for this type of climbing.
First, I've found that momentum is key. Getting as much speed before hitting the hill really helps.
Second, I usually lean forward over the bars, but if I get to a section of the hill where it gets steep, I'll actually lean back to put more weight on the back tire (but not enough to lift the front wheel off the ground).
I'm able to get up almost every hill in the normal trails I ride. However, there is one hill that gets me every time. At the bottom of the hill is a small stream which the best way to cross is via a concrete bridge off to one side (the rocks in the stream are too big to blast through). Actually, it is more of a narrow concrete slab with water running over it. So, after the bridge the momentum is less than what I'd want it to be. Next, the hill has a bunch of rocks and loose material going up. I usually make it up about half way and then end up kicking out some rocks and loosing momentum altogether. Local riders say that a few people have made it up.
Anyone have any tips?
