1 - 3 of 3 Posts
Hi all,
I have a chance to get a set of Stan’s 26” wheels with 3.30 hubs, but I need to convert them from 12x142 back to 135qr to fit my frame. Do I just need the end caps or do I need to replace the axle as well?
Thanks in advance,
C
I think you can probably go from 142 to 135 QR by just getting the end caps. You should verify which axle you have, type 1 or type 2 as end caps are axle and driver specific. Type 1 axle is threaded on both ends, type 2 is threaded only on one end. Once you know which axle type you have and what driver you want to use, it's best to call Stan's and they'll tell you what you need. They've been really helpful whenever I've called them.
1 - 3 of 3 Posts
