Silver fillets = scary
If I were doing this project (which I think is a neat one) I'd either TIG the frame, build with appropriate stainless lugs (there are plenty to choose from), or else make some lugs with the lathe and tig them together (if the commercially available lugs aren't appropriate), then silver braze in the main tubes. Any of those solutions would work well, I think.
I know there are a couple of people who have done silver fillet brazing in the past (and possibly present). Jalon Hawke is a name that comes to mind. But I also know that unless you're a *master* at the technique, it is super dangerous - the fillets can crack very easily as they cool, as the silver changes volume quite a lot when changing state. I don't think redundant supports (other than lugs) will be enough to hold this together.
But then again, I am not the fillet expert. See if you can find some info on the framebuilders/phred archive. I know this kind of thing has been discussed.
-Walt
-Walt
mchimonas said:
