looking to upgrade from the rear stock hub on my bianchi sok. looking for quicker response...any suggestions??
The design of the King ring-drive is much more durable over the long haul. There is no competition in that respect.Having owned i9, CK and DT240 with the 36pt upgrade, here are my observations:
i9 is a better hub than CK; it has better engagement and spins much smoother. They are both plenty blingy for anyone that is into appearance.
From my experience, it's a myth. I had two CC hubs, and both slipped. Granted, I ran a very high gear (42/16), but that has never happened to me on DT Swiss. My CC stalwarts rose the defend the brand, but that's my experience.The design of the King ring-drive is much more durable over the long haul. There is no competition in that respect.
Oh yeah, I remember that thread now...like I said then, if 42/16 was too tall of a gear, then pro road racers wouldn't be riding the same internals with higher gear ratios. It was a problem with setup.From my experience, it's a myth. I had two CC hubs, and both slipped. Granted, I ran a very high gear (42/16), but that has never happened to me on DT Swiss. My CC stalwarts rose the defend the brand, but that's my experience.
With I9 I've gone from QR -> Bolt -> 20mm ->25mm on the front axle and have been pleased with each update. Rear I've gone from QR -> Bolt axles using Chub Hub rear bolts and retainer cups for increased stiffness. I9 can be bling, but still adaptable. Only complaint is their bolts used with the button cap bolts. Would rather see socket caps with washer for a more reliable bolt / tool interface especially considering high torque loading.The adaptability is also one of the best in the industry (there are kits to switch between Q/R, Bolt-on and Through-Bolt).
So, if bling is most important to you, or engagement is on the top of your list, go i9; otherwise DT240 is way to go.
