Hi Everyone,
I bring questions and thoughts about SS cranks. I've been running an older XT crank (probably 2001), for the past few years on my SS chameleon. Although mechanically, it's been pretty good - it's extreamly loud. It's a ticking sound on the non drive side when climbing (and some seated high torque spinning). I've spend loads of $$ and time over the past year to have it looked at - BB pull/relube, different chainring, freewheel, chain, etc... The only thing I haven't completly replaced is the crank itself. I can't tell you how much this ticking is driving me crazy... This year alone, I've replaced several things on my drivetrain: bought a 34t salsa stainless, SS sram chain, and a shimano 17t freewheel, new ES-70 BB (or whatever the splined one is). Still, I have this ticking. Crankbolts are tight, BB and crank are torqued properly, but nothin' is fixing it.
So, not I'm left with possibly having to buy a new crank. Frankly, I'm thinking about going out and buying a new LX crank - it will be compatible with my current BB, and I have the tools to install it. However, I wonder if my problems are due to bottom bracket - specifically, it rubbing up against the plastic cup on the non drive side...
The other (more scary) option is to get a new frame. My LBS had to retap and face the BB cavity because it's been pulled so much. I've never had a problem with it coming loose, but it's been serviced several times.
Lastly, it could be that I have a crack in my frame... I've cracked 2 gary fisher paragon frames in the last 4 years (and finally went with a chameleon). I looked the frame over, but could not find anything. Ironically, the creaking on my GF frames was only on the non drive side.. But that was more of a creak, this current issue is a tick/plastic rubbing sound.
As you can see, I've given alot of thought to this. It basically, ruining my love to ride. I *hate* having to listen to anything but my freewheel buzz during my ride....
any advice is welcome (including recommendations for a good therapist
mm
mm
