1 - 13 of 13 Posts
~Disc~Golf~
I just found an old Rock Hopper (mid '90's??not sure) behind my dad's shed during my last visit and I figured it would make a great SS project bike. I want something kinda fast and light - but not really for hard core MTB (I'll leave that for my 6" geared dualie), just an errand/school bike that will occasionally see some smooth dirt.
I've pretty much completely stripped everything off and replaced the necessities with some parts I had lying around - BB, cranks, headset, wheels etc. All except for the rear cog/hub. I have a LX hub (8 spd. previously) that is in great shape and was hoping to use it.
My idea was to break down an old cassette and find a suitable gear ratio and use something like PVC for spacers. Is this a good idea? Or should I get a different hub (BMX?) All of my buddies who ride SS or fixies have purpose built hubs, but I was really hoping to build this up w/out spending one red cent.
Oh, and speaking of gear ratios, I've read a bit on here and got that a 2:1 is a good place to start, but since I'll mostly be on flat and level tarmac, I was thinkin' of going with something steeper like 2.5-6:1??
Thanks for any input on my current situation and for anything I may not have thought of...this will be my first SS (besides BMX back in the day :) )
Certainly you could use your existing wheel and space the freehub to use a single sprocket.
I'd suggest using only sprockets from your existing cassette to find a ratio that suits you and then buying a SS specific sprocket (Surly for example) with full depth teeth.
You'll need some sort of chain tensioner too - get one that can tension by pushing up.
Sorry mate, I forgot that some of those Rockhoppers have forward facing horizontal dropouts....:eek: . I'm not that well up on Specialised stuff.
In that case - yes, a half link (if you need one) and maybe a chain tug on the drive side should get you up and running :) .
~Disc~Golf~
Discussion Starter · #5 ·
Andy R said:
...and maybe a chain tug on the drive side should get you up and running :) .
yeah... how does that work for forward facing drop-outs? There one on there now (well similar i guess) that looks like it works the same as a chain-tug for rearward facing drop-outs. But it would just push the axle forward (or keep it from going back) from my perspective. Is there something that I'm missing?
-THX
-THX
Is there a hole on the dropout?
On both of them actually. Hole, then forward facing dropout...
Jam Econo
If you're mostly on flat roads I wouldn't worry about axle slip too much, just honk down on that LX QR good and tight.
If you do have any issues you could swap out the axle for a solid one, and get some good track nuts like these Problem Solvers w/ rotating washers (I run them on both my road and mtb fixies w/ zero problems).
Try a cog from your cassette. Keep on riding it until you start dropping the chain. If you don't drop the chain, just keep on riding it.
-THX
I'm sure that it's possible to use a Surly tug with forward facing dropouts. However, I can't speak from experience so maybe I'm wrong. I'm think that I've seen a photo of just such a set-up though...
organically fed
I made the switch to SS when I was still in Chico and I was very happy with 2:1 (32x16). All over the road, Lower Park singletrack, Upper Park rockgardens, even up the North Rim Trail, that gear combo worked for me.
Be prepared to feel like a kid on a new bike again. :thumbsup:
~Disc~Golf~
Discussion Starter · #10 ·
i'm sorry, but I don't quite follow...hole=forward facing???
yeah, I've got a solid axle and some nuts lying around that I was gonna swap out for the QR - I dont think I'll have any probs. I just could not see how how chain tugs would work w/ fwd facing drops - I guess I need to see a photo
[QOUTE=w00t!]I made the switch to SS when I was still in Chico and I was very happy with 2:1 (32x16). All over the road, Lower Park singletrack, Upper Park rockgardens, even up the North Rim Trail, that gear combo worked for me.
Be prepared to feel like a kid on a new bike again.[/QUOTE]
yeah..I'll be running a 42 up front, so I think I'll start off with a 21 out back then - If I'm spinnin too much, then I'll just throw on the next gear up ( 18t i believe)
1 - 13 of 13 Posts
