So I just installed a Sram x9 type 2 RD and 10 speed shifter. I got everything dialed in and took the RD all the way up the cassette from the smallest cog to the largest. I shifted up to the next cog and that worked fine. Tried to shift up again and didn't get a click. The trigger moves but doesn't click to release cable tension. Then all of a sudden it decided to give and it shifted fine after that. Took it for a trail ride a few days ago and I had the same problem. Didn't want to shift until I pressed it a few more times and it finally clicked and up shifted to a smaller cog. Luckily it only happened once on the trail but once I got home and put the bike on the stand the same problem occoured. This time I'm not so lucky and it seems like it's totally stuck, the shifter works but will not shift to smaller gears. I can shift down into the easiest gear and back up one gear but it wont work after that. Under Sram warranty it looks like I will need to call the shop I bought it from on amazon.com In the mean time I wanted to know if anyone else has had this problem?
