I don't think this video really means anything.Disco_Inferno said:
No, really, your friend's bike wasn't set up correctly. Your chain shouldn't fall between your spokes and your cassette, regardless of what derailleur you're running. Because of this, I don't understand how you're saying that XTR is better than X0.m4dj4ck said:His XO keep on skipping the chain and eventually, the chain fell into cassette during the race! You cant lost any time during race. While my xtr, despite the damn noises, was shifting smoothly(using deore shifter) and no chainslap/chain-skipping at all. While you guys may say that my friend's bike wasnt set-up correctly, i think it the same for xtr as well.
Your friends derrailleur was incorrectly adjusted. Nevertheless you make the point a lot of people don't get. Both systems work outstandingly well when they are correctly setup. Sram setups are not impervious to problems and malfunction just as bad when they are not setup correctly or when there are other dricetrain problems along the line.m4dj4ck said:well i came across this video few months ago and i was using xtr rear derail(RD-M960) that time. At first i was so impressed until i nearly sold off my xtr drivetrain and get sram xo instead. But, having some financial issues, i sticked to xtr until now. Of course, i hate the noise when the body of derail hit the chainstay but it wasnt that bad at all. You will get used to it soon. I had a friend who is using sram xo components and taunting me to change to sram as well. And so, we went to plenty of XC races already and guess what? His XO keep on skipping the chain and eventually, the chain fell into cassette during the race! You cant lost any time during race. While my xtr, despite the damn noises, was shifting smoothly(using deore shifter) and no chainslap/chain-skipping at all. While you guys may say that my friend's bike wasnt set-up correctly, i think it the same for xtr as well. It is just the noise issue. The noise hitting chainstay doesnt mean the derail will break out. Even if, i think shimano already having some trouble since the first month they release this derailleur.
yeah..but maybe i didnt point it right. what i mean is my friend's bike wasnt set up correctly and also, the shifting problem will happens if xtr isnt set up correctly as well.m4dj4ck said:well i came across this video few months ago and i was using xtr rear derail(RD-M960) that time. At first i was so impressed until i nearly sold off my xtr drivetrain and get sram xo instead. But, having some financial issues, i sticked to xtr until now. Of course, i hate the noise when the body of derail hit the chainstay but it wasnt that bad at all. You will get used to it soon. I had a friend who is using sram xo components and taunting me to change to sram as well. And so, we went to plenty of XC races already and guess what? His XO keep on skipping the chain and eventually, the chain fell into cassette during the race! You cant lost any time during race. While my xtr, despite the damn noises, was shifting smoothly(using deore shifter) and no chainslap/chain-skipping at all. While you guys may say that my friend's bike wasnt set-up correctly, i think it the same for xtr as well. It is just the noise issue. The noise hitting chainstay doesnt mean the derail will break out. Even if, i think shimano already having some trouble since the first month they release this derailleur.
As an SRAM user, I've followed this phenomenon with a degree of skepticism. I'm not denying that they break, it's obvious that they do. I just have a hard time believing that there is no outside force responsible for the breakage. Too many people say the same thing...JRA and POW!, my derailleur exploded. My simplistic mind tells me that something within the realm of physics or engineering has to be at work here. You seem to hit on something with this pivot issue. Can you explain what it is about the difference between the SRAM design and the Shimano design that makes the SRAM prone to breakage? I'm not being confrontational, just looking for an explanation.Hecubus said:http://forums.mtbr.com/showthread.php?t=116364
For those that don't follow here regularly the amount of reports on SRAM derrailleurs breaking like this is overwhelminghly higher than any other. Sram derrailleurs have suffered from this design flaw since they carried the Sachs name. That main pivot serves a very important purpose.
Lol! I know I risk a flame war by bringing these issues up. I started to come up with that suspicion several years ago long before the X series existed. I used to ride Sram for some time many years ago but it was really a some buddies of mines experience where I started to pick up on the issue. They managed to break 5 Sram derailleurs JRA withing the space of less than 2 years. 3 of them broken exactly the same way, around the main bolt. All of them were the original 9.0's and 9.0SL's. The other two were X.0's broken at the knuckle which is another well known failure point. At races I've seen even more of them with again the same problem. Thats just from my personal observations. Then when I come here I keep seeing more consistant reports of EXACTLY the same problem with them. The amount of reports on the issue is disproportionate to any other derailleur kind. Its obvious there has to be a common design issue causing this. I certainly have seen my share of broken Shimano derrailleurs. Cracked parallelograms, broken parallelogram pin pivots, exploded cages, mangled and twisted main bodies but never anything that indicates a consistant design issue. Almost always damage caused by violent impact with the ground or large sticks. The numbers of them broken also seems to be much smaller in comparisin even though they outnumber the sram parts like 3 to 1.Call_me_Clyde said:As an SRAM user, I've followed this phenomenon with a degree of skepticism. I'm not denying that they break, it's obvious that they do. I just have a hard time believing that there is no outside force responsible for the breakage. Too many people say the same thing...JRA and POW!, my derailleur exploded. My simplistic mind tells me that something within the realm of physics or engineering has to be at work here. You seem to hit on something with this pivot issue. Can you explain what it is about the difference between the SRAM design and the Shimano design that makes the SRAM prone to breakage? I'm not being confrontational, just looking for an explanation.
Thanks in advance.
Bob
