SRAM has launched an updated rotor design that it claims is quieter and more powerful than its predecessors. The all-new HS2 Rotor is a mountain bike-specific rotor designed to improve brake performance while reducing noise and increasing heat dissipation.
1946409
Related: The Best Mountain Bike Brakes for Every Type of Riding
The new HS2 rotor is 2mm thick. This is slightly thicker than the rest of the rotors in SRAM's Centerline rotor line, which measure 1.85mm across. The increased width helps this rotor better manage heat, as does thermal dissipating paint on the recessed rotor arms. The HS2 also features a new brake track pattern for increased pad traction. SRAM claims this results in a 7-percent increase in stopping power.
1946411
In addition to a slight boost in stopping power, the HS2 features an impressive reduction in running temperatures. According to SRAM, the HS2 rotor ran 40°c cooler during on a Garda test track.
1946410
SRAM is offering the HS2 in 160mm, 180mm, 200mm and 220mm sizes for six-bolt and Centerlock standards. Pricing ranges from $50 to $65 depending on the rotor diameter. According to SRAM, the HS2 will be the standard rotor option with new SRAM brake systems going forward.
Visit www.sram.com for more information.
Related: SRAM GX Eagle Expanded Range Drivetrain Review
