Hello,
the drivetrain of my 2011 Stumpjumper FSR Comp 29er is worn out.
It is a SRAM 10spd setup. 2x10 - Specialized/SRAM OEM S-1250 crankset with 33/22 teeth alloy chainrings. A Shimano Dynasys cassette (SLX I guess) and a Shimano Dynasys chain.
I´ll buy a XT level Dynasys chain and a 12-36 XT level cassette - but I am not sure what chainrings will fit on the crank.
It is a 4-bolt type 104mm dia. I don´t care if the replacement ring is 32 or 33 tooth. The SRAM chainrings are really, really expensive from what I see.
I´d like to replace them with steel chainrings. Don´t mind the weight, would appreciate higher longevity. I don´t know if the SRAM steel chainrings (which are cheap) will fit.
Anyone tried this?
Might Shimano chainrings fit?
Ditch the Sram crank and get a Deore crank instead? Complete with bottom bracket and chainrings it is cheaper than a single big SRAM alloy replacement ring...
Might not work with the 2spd SRAM front derailleur then...:nono::nono:
Greetings and thanks for any input!
Znarf
Anyone tried this?
Znarf
