Hello
Last year i bought a used 2020 Orbea Oiz M-ltd, with Sram Level ULT brakes, and i noticed that the brake pads is not worn 1-2mm at the top:
I thought that it probably had the wrong pads, so i changed them to new ones (which orbea confirmed is correct), but the same problem happened again.
So, i contacted the Orbea dealer where the bike was bought and they said that it's normal for pads to not wear at the top, and that it happens more often with worn brake rotors.
So i bought new Shimano RT-MT800 rotors and test fitted them, same problem, so i took them off.
If the problem was only at the back brake, it could have been a manufactering defect with the frame, but it happens at the front too, wich is a Fox factory 32 SC with the corect spacer.
Any suggestions ?
More pictures:
Any suggestions ?
More pictures:
