Hey All;
My 18’ Santa Cruz Tallboy came with Level TLM brakes and 180mm rotors front and back . The power seems fine for our MI XC trails even though I’m 220lbs. However having a couple issues with noise and the paint on the caliper edges wearing off.
The rear develops a warble noise under heavier braking and the front a squeak on initial braking.
I sand the pads, align the calipers, sand and clean the rotors with brake cleaner and re-bed each. They will be fine for a few rides however the rear requires constant attention mostly sanding the pads to remove a black layer of “stuff”.
I have tried new Sram pads on rear with the same results. The Cool Stop pads in the rear are better.
I’m considering to take into my local shop for them to look into it and the caliper paint wear.
In was going to try some Shimano one piece rotors that have have a different cutout pattern however not sure it’s worth the $$.
However, unfortunately I think some replacements may be in order. I’m thinking some Guide RSC or Ultimates. I get mixed review on the Shimano’s and kinda like the Matchmaker setup for the shifter and dropper. Not sure...
Thoughts and suggestions on keeping the Levels, caliper paint wear, new rotors or just ditching them for something else?
Maybe unreasonable I would like Sram or Santa Cruze to fix, replace or upgrade, as these issues shouldn’t come from brakes 7mo old.
