Read that whole manual. Had no clue there were that many parts of a brake.I want to replace the 2 small o-rings to connect the 2 caliper halves once you separate the chambers of the SRAM Guide R brakes. Does anyone know the o-ring size for these please? View attachment 1959637
Yes I did the google search prior without a result - hence why I asked on the forum. Yes the RSC will be the same size.. Is the 4.5 the outside diameter of the oring?Read that whole manual. Had no clue there were that many parts of a brake.
Don't bother googling, it's impossible to find cause SRAM doesn't list the sizes anywhere. Probably cause they want you to buy the whole kit. Not sure if they're the same, but it's size 4.5x1 on the RSCs.
Yes, it's measured in outside diameter (cause thickness varies so inside isn't always the same). I have about 50 of em that are part of a set I'll never use. Would be happy to mail em to you if you drop a message.Yes I did the google search prior without a result - hence why I asked on the forum. Yes the RSC will be the same size.. Is the 4.5 the outside diameter of the oring?
