SRAM flat mount rear caliper options
916 Views 6 Replies 4 Participants Last post by  p0is0n0ak
I have a Turner Nitrous that came with SRAM Level TLM levers, running a Level TLM caliper on the front and an Apex flat mount caliper on the rear. I tried metallic pads but still couldn't get the power I wanted so I replaced the front brake with Code RSC lever and caliper. It's now good, but a little overmatched for the Apex caliper on the rear.
Is there a better SRAM flat mount rear caliper than the Apex, or would they all work about the same? Likewise, would I see an improvement replacing the Level TLM lever with a Code RSC lever if I kept the Apex caliper?
1 - 7 of 7 Posts
Is there room to adapt to post mount?
Great question. Didn't realize it might be that easy.
Maybe even easier than that… when they're in stock, that is.
Road - RX4+ Caliper (hopetech.com)
  • Like
Reactions: 2
In my discussions with SRAM you can Not use a Guide lever with a Level/Apex/Force/Red etc caliper. They have different ratios between lever and caliper. The Apex caliper has the same size pads and works the same as a Level caliper, just different mounting style. If you need more power try a 180 rotor and an adapter. I would be surprised if this does not lock up the rear wheel at will.
Tool Bicycle part Rim Composite material Font
  • Like
Reactions: 2
+1 on this option. Love the Rx-4s!
  • Like
Reactions: 1
1 - 7 of 7 Posts
