1 - 8 of 8 Posts
· Registered
Sram pulls more cable per shift. A 9 speed cog has a seperation of 4.35mm from the center to center between each cog. Sram ESP pulls 4mm of cable per shift while Shimano pulls 2.5mm per shift. That gives you a ratio of 1.1:1 for Sram and 1.7:1 for Shimano. The misconception that the pull ratios are 1:1 and 2:1 respectively are rounded off numbers by Sram's marketing to make the difference seem more impressive.
· Compulsive Bike Builder
Discussion Starter · #3 ·
Great, thanks
The if that is the case, it is unlikely that a Shimano friction shifter - say 8/9 speed bar cons - will throw enough cable to shift a SRAM ESP type, say an X-9. While you would not have to worry about cable per shift with index, you would not be able to throw the cage all the way across the cassette.
Without setting it up and trying it, that sounds like the logical conclusion, no?
· Formerly DMR For Life
your going to need more cable movement @ the RD to move it one cog with the sram than the shimano....roughly you would have to move the shifter 2 indexs to get the RD to move one cog...and as a result you couldn't get much more than half way across the cassette
does that sound right?
DMR
· Registered
DMR
The Sram pulls only 60% more cable than the shimano. That will means an ESP derailleur will move about 7 cogs with 9 clicks on a shimano indexed shifter.
yes that right but you would have a significant problems with the RD making noise and such because with one click you wouldn't move the RD enough, but with two you would move it to far but not far enough to get it on to the next cog if you get what i'm getting at
DMR
· Registered
DMR
Yeah I do. The spacing would be either too short with one throw or too long with two. It just wouldn't line up.
1 - 8 of 8 Posts
