I was banging my head trying to get the shifting dialed on my Eagle setup. the hangar was true, the housing was fresh, and almost everything was adjusted correctly. The problem turned out to be that the B gap was not correct. Sram makes a handy tool to set the distance but you can also set it by measuring 14mm between the cog and pulley in the highest gear. I found it difficult to do this with calipers or a measuring tape because you have to contend with the chain, wheels, frame, etc. the trick I found was a simple wooden carpenter pencil. the width measured exactly 14mm and can be fit through the wheel to take the measurement. If the pencil is bigger than 14mm you can just shave it down to the correct width.
