fedup2 said:
I about to switch over and try some xo sram stuff but i wasnt sure what kinda xo derailer to get! I ride mostly XC and i want a derailer that needs the least about of ajusting!please help me out.Also what disc brakes do you guys recomend,I just bought a 06 blur xc and i am building from scratch. I'm a newbie to this board!!!
thanks,brettxxx
Derailler length is based on the range of gears you have. If you run 3 front rings, and have say 11-34 rear, go with the long cage der.
Brakes - almost all newer mid-high end hydro brakes are very good, with small differences that are often personal preference. Some are lighter than others, so better suited to XC.
Avid Juicy 5 or 7
Formula K24 etc
Magura - not sure the current best model
Shimano - LX, XT, XTR - only issue is splined rotors, they will work with 6-bolt rotors though.
Hope mini mono
If it was me, I'd base the decision on which decent, lightish brakes you can get a deal on, that you can get servicing and parts for locally (unless you DYI servicing and don't mind mail-ordering parts).
