So my bike has a Dub BB92 pressfit bottom bracket. I wanted to upgrade it to maybe a Chris King. Question what should I be looking for when I purchase a new BB. The crank has a 30mm spindle. Will a PF30 work? I've searched the Internet without really getting a straight answer
You've got a lot going on and I'm not sure you gave all the necessary info.
First, you say your crank has a 30mm spindle. Is this a new crank? Or did it work with the Dub BB? This is important.
Second, the BB92 standard was designed around a 24mm spindle. The old SRAM GXP worked well for this, too. Anything else is a bit of a kludge. GOOD bottom brackets for this fitment are sorta uncommon. There's really only one out there, and it's sold by a few manufacturers. Enduro, Hope, e13, wheels, etc.
https://wheelsmfg.com/bottom-brackets/bb86-for-30mm.html
https://www.endurobearingsonline.co...ntain-bike-bottom-brackets/products/bb86-4130
https://www.hopetech.com/products/drivetrain/bottom-bracket/press-fit-41-30mm-bottom-bracket/
https://bythehive.com/products/press-fit-bottom-brackets
DO NOT buy the RaceFace PF 41 30 bb. I used one once (before all of these were available on the market) and it was grindy trash in probably 1/4 of the mileage. I've been using the bb sold by Enduro with steel bearings.
You have 3 basic dimensions you have to work within as your constraints.
1. bb shell diameter. If your frame has a BB92/DUB bb in it now, then that shell is 41mm in diameter. Nothing else will fit. PF30 requires a 46mm bb shell.
2. Spindle diameter. Pretty self explanatory.
3. Shell width. BB92 shells (or more accurately, PF41 shells), in particular, can be found in multiple widths. The original is 92mm wide, the same width as a 73mm threaded shell plus bb cups. You'll see them in fatbike widths, too. Originally, mfrs called them PF41 shells, with xxx width. Now, they're using consistent terminology with the original standard and calling them BB121 or BB131 (less common). It honestly doesn't really matter for the most part. It's really only relevant for the ones that have a plastic sleeve between the cups inside the shell, for protection against water. And even the sleeves mostly aren't necessary.
So, Chris King doesn't make a bottom bracket for this fitment. Probably never will because it's a kludge anyway.
