I've got a new Sugino XD crankset and a fairly new (6 month old) Shimano UN-54 cartridge bottom bracket. I've maybe ridden 100 miles, and have been trying to isolate and eliminate a "clicking" noise.
I had a noise from my left crank arm originally. I removed, wiped down the spindle taper and put loctite on the threads and torqued it pretty well. That side seems fine. I did the same thing to the right, but still have a slight click when the arm is at 1:00.
I'm hesitant to over torque and strip the taper or worse my new crank arm, so should probably purchase an 8mm hex socket.
Anyhow, back to my subject line - should I be putting bicycle grease on my crank bolt threads instead of loctite? That's what parktool recommends:
http://www.parktool.com/repair/readhowto.asp?id=103
