Just got a 5th Element 5 way with a 400lb spring, which is way to heavy for me. I went to TFTuned's spring calculator and it said I needed a 332lb spring but they only make 300's and 350's that will fit my shock. This is on a DH bike so plush ness is a must but it should also be able to take drops without bottoming. I have heard that the shock itself will not bottom out if set up correctly and that the spring rate does nothing but set sag. What do you guys think?
