1 - 20 of 26 Posts
Hi suppose u want to find a use for a used cassette that still shifts ok but you can clearly see some rust at the back of the spider/cogs? Would spray painting the entire cassette black protect it from rust later on or trying some chemicals to actually remove the rust be a better option?
Neither. Once rust gets on steel, it's almost impossible to get rid of it. Spray paint will only cover it up temporarily. Phosphoric acid can be used to try and stop it, but it's pretty hazardous. Anything you put on the cassette will come off if it's where the chain contacts the teeth.
I would just hit it with degreaser and a wire brush to clean it up. Dry thoroughly, apply some chain lube to all surfaces and ride it!
Discussion Starter · #7 ·
Hmm i can't get hold of acids and that home depot rust remover but i have read about "descaling agents" and i think i can get hold of some in powder form where one mixes it with water to form a solution? Do u think those can work?
Cycologist
Is it worth the time, effort and money? How bad is the rust and how much life is left in the cassette? Ride it until it's done and then buy a new one.
Discussion Starter · #9 ·
well the rust is clearly evident but i like to experiment and learn stuff especially when it comes to bike parts maintenance and possibly salvage :p i dun really mind if it costs some coin as i learn something new and gives me a sense of satisfaction ^^
Single(Pivot)and Happy
Ok one sec would upload - ok done ^^ Its a 9 speed Acera class Shimano cassette
You linked images of brand new cassettes. I know what a brand new shiny cassette looks like. What I don't know is what your rusty cassette looks like.
Spray painting is not an option unless you are going for the hillbilly white trash "meet my 1st cousin/wife" look.
Elitest thrill junkie
Definitely. My brother was in the US Navy and said that they regularly painted over rust. If it's good enough for the US Navy...
Co Springs
lol
Putting a fresh coat of paint on anything will Fix It !
*Good enough for Government Work / painting over rust = sweeping dirt under the rug is to house cleaning. :cool:
OP- Have fun with your restoration project ! SEE HERE;
Doesn't look that bad. If it were me... WD40 it and wire brush.
Can you separate the cogs? If so, do so and wire brush 'em. All except the large aluminium cog.
Get the WD40 off and keep it oiled.
Discussion Starter · #19 ·
Wow did not expect so many helpful insights and tips so thks all! I shall try it out and if successful would def share my experiences back here for the benefit of the community :thumbsup: Hmm only the 11 & 13T cogs are removable with the rest bolted/riveted on to the spider me thinks?
Administrator
check the back of the cassette, there might be screwed pins, might be rivets. If screws and not too rusted you might be able to remove them.
1 - 20 of 26 Posts
