I did a search on sprags & found lil' to nuthin' of a definition of sprag. However, my bro says it's a oneway clutch that freewheels one way & engauges the other. He says automatic transmissions in cars & trucks have'em in them.
As far as I know there aren't any currently available that can be made small enough and still handle the loads required. Weight becomes an issue as you make them larger of course and then fitting them within the current geometric constraints creeps in to the equation. Not saying it couldn't be done though.man w/ one hand said:I was czechen out the latest issue of Decline & saw the DT Swiss advertisement with the star ratchet hub & my brother, a mechanic, asked me why don't they build hubs with a sprag instead of star ratchets & pawls. He explained they were bomb proof, instant engaugement & most importantly CHEAP! Anyone ever tried a sprag application that you know of ??
O'yeah......Merry Christmas !!!!!
I was wondering about size. Bicycles have space and weight issues that are less of a concern it other applications.Mike B. said:As far as I know there aren't any currently available that can be made small enough and still handle the loads required. Weight becomes an issue as you make them larger of course and then fitting them within the current geometric constraints creeps in to the equation. Not saying it couldn't be done though.
No idea if they use the sprag clutch. I do know that red-haze killed one (SS version) in 4 months. A NovaTech SS hub with pawls/ratchet takes all he can give it.Ligero said:I could be wrong but I thought True precision hubs use a sprag clutch in their hubs.
http://trueprecision.net/c_products_mountain.html
This is something different, but it's worth checking - just click "technique" and than "ROLLIN' ROLL" in the menu.man w/ one hand said:I was czechen out the latest issue of Decline & saw the DT Swiss advertisement with the star ratchet hub & my brother, a mechanic, asked me why don't they build hubs with a sprag instead of star ratchets & pawls. He explained they were bomb proof, instant engaugement & most importantly CHEAP! Anyone ever tried a sprag application that you know of ??
