I got mine a few weeks ago. The new design works greatbrewdog said:Anyone know if the Transport 2 rack(w/ratcheting arms) will work with 29" wheels/tires?
I have used the older model that has the bungie sprung arms. It requires tire deflation to get the arm all the way over the wheel.
I had the T1 with the "hoops" and did not like it and sold it. Then I purchased the T2 with the "trays" It works great.brewdog said:Which one of these do you have?
No. However you can get longer arms for the T1 (T2 arms) I have an extra pair. The tire does not fit down all of the way inside the hoop but it works.brewdog said:Will the hooks of the T1 open up enough to fit all the way over a meaty 29" wheel w/o having to deflate the tire?
Looks goodkustomz said:I have type 1 or the spring loaded cane style that I use for hauling my 29er. I did make a few modifications to make it more friendly. I removed the foam rubber sleeve and this allows the cane to come up and over the tire without interferance. I also installed a bar end to give something to pull up with.
and it works fine.brewdog said:Which one of these do you have?
