This is a new to me, and has me doing a little head scratching.
Just did a Boostinator conversion on my I9 Torch / LB Carbon / CX Ray rear wheel. After redishing the wheel and bringing tension back to 120kgf I've got spokes kissing the cassette under hard loads or turns. Really puzzled here since the dish should have brought the spokes farther away from the cassette. I think I'm going to take the cassette off and tap the outside spokeheads a bit and see what that does. If that doesn't work I guess I'll see if I have an old 1mm cassette spacer in my junk box or grind the spider a bit.
Just thought I'd share since it's an odd situation.
You can see the bright ring where the ano is worn off in the pic below.
