I think it should be ok. 2mm is as far off the ideal length as I'd go when building a wheel, but i'd prefer to have them closer. Any shorter than 2mm and there's not enough thread engagement...too long and the threads might bottom out before proper tension is achieved. Also if they're too long and you're using single wall rims, you'll have to grind off whatever is protruding beyond the nipple.
I'd say build the wheels too find out how the spokes fit. I've built wheels with spokes the length that was calculated for the rim/hub combo and they were sometimes either a bit too short or long. I like to use a few different spoke length calculators, plus doing my own math and comparing lengths.
