the #6 said:
I've noticed 2x spoke patterns on some MTB wheelsets and wonder about their durability. If I'm not mistaken, Stan's newest ZTR Race wheelset uses a 2-1 cross in the rear? Is that 2x on the brake side and 1x on the drive, or vice versa? And how well would something like this hold up to average cross country riding? I've always used 3x spoked wheels and see the disclaimers that disk brake manufacturers have saying to only use their brakes on 3x wheels. What gives?
Most wheels with fewer crosses also have fewer spokes. This is entirely normal and necessary as with fewer spokes you can not have as many crosses without having issues with spoke overlap at the hub flange.
Basically, a 4X 36 spoke, 3X 32 spoke and 2X 24 spoke wheel all have about the tangental spoke angle. It is also common for a 28 spoke wheel to be 2X.
It is the tangental angle that lets the wheel transfer torsional (rotational, drive/disc braking) loads. The closer the angle is to 90 degrees the better. The wheel will generally be more stable.
The number of crosses has little to do with the lateral "stiffness", though in some cases fewer crosses can increase it.
It appears Notubes is doing it on 32 spoke wheels for weight reasons. Not a pattern I would want.
