Spindle length - Commencal Ramones 20"
916 Views 4 Replies 3 Participants Last post by  zach.pink
Just picked up a used Commencal Ramones 20" for one of my sons. I'd lake to swap the crank and bottom bracket.
Frame: 73mm BB shell
BB: cage bearing, square taper, 130mm spindle
I'm swapping to a 127mm crank(also square taper) and want to replace the BB with a inexpensive sealed bearing unit. With the 127mm crank on the orig BB (130mm spindle) there is about 15-20mm between the crank arms and chain stays.
In researching what Shimano and others offer I can't find a sealed BB for 73mm shell with 130mm spindle. My question is, given the amount of clearance between the crank arm what length spindle should I use? How short can I go without interference with the chain stays?
The bike will be set 1*9 or 1*10
Thanks in advance
Sent from my moto x4 using Tapatalk
1 - 5 of 5 Posts
Based on what you are describing in having 15-20mm clearance with a 130mm spindle, I don't see any reason you couldn't go with the narrowest Shimano BB-UN300 at 73x113. Cambria Bike and others have them for under $20.
  • Like
Reactions: 1
Just picked up a used Commencal Ramones 20" for one of my sons. I'd lake to swap the crank and bottom bracket. Frame: 73mm BB shell BB: cage bearing, square taper, 130mm spindle I'm swapping to a 127mm crank(also square taper) and want to replace the BB with a inexpensive sealed bearing unit. With the 127mm crank on the orig BB (130mm spindle) there is about 15-20mm between the crank arms and chain stays. In researching what Shimano and others offer I can't find a sealed BB for 73mm shell with 130mm spindle. My question is, given the amount of clearance between the crank arm what length spindle should I use? How short can I go without interference with the chain stays? The bike will be set 1*9 or 1*10 Thanks in advance Sent from my moto x4 using Tapatalk
Did you figure this out? I just got the same bike for my daughter and the cranks are waay to long for her.
You may have already found a solution. I ended up swapping out the crank for a set from Prevelo. Mine predate the Heir model shown on the website but they look very similar
I found set from Alibaba. Goldix. Had a bb and crankset for $50. Seems to be working great so far.
  • Like
Reactions: 1
1 - 5 of 5 Posts
