1 - 5 of 5 Posts
What front derailleur do you have on your Spider? Mine came with an XT, but after some shock maintenance, I noticed the rear triangle rubbed just a bit when in the little ring. I lowered it about and 1/8", but then the the chain guide rubbed the teeth on the big ring. I was able to move it up just a hair, but this seems awfully close, with respect to both the chain ring and the rear triangle. Let me know what you're running.
Matt
Its only 1" on the map!
Matt
I have an XTR and if it aligned just right there is no rubbing. However, it does not have to be misaligned too much to rub. Once setup, there is never really much need to tweak it.
1 - 5 of 5 Posts
