the site has worked fine for me all day/week
FRAME Demo 8 FSR frame, super low center of gravity and standover with sub-seatstay actuated shock, full cartridge bearing pivots, 26" F/R wheel, 8" of travel with full chainguide and front derailleur compatibility, ISCG mount, rear derailleur protector, 26 and 24" wheel compatible with two geometry settings, 16.7" chainstay length, forged and CNC'd OS HT, Super ORE TT/DT, Demo tool
REAR SHOCK Fox DHX 4.0 coil 8.75"x2.75", adjustable rebound, ProPedal, IFP pressure
FORK Marzocchi 888 VF2, 200mm travel, flat crowns, external rebound adjustment, integrated stem, 20mm thru axle
HEADSET 1 1/8" alloy upper with OS bearing, 7050 alloy lower cup with 13mm insertion
STEM Integrated Marzocchi 888 for 31.8mm bar
HANDLEBARS Specialized Demo rise bar, 6066 alloy, 31.8mm, 6 degree upsweep, 9 degree backsweep
TAPE GRIPS Specialized MTB grip, natural/black
FRONT BRAKE Avid Juicy 5, hydraulic disc, 8" Polygon rotor
REAR BRAKE Avid Juicy 5, hydraulic disc, 8" Polygon rotor
BRAKE LEVERS Avid Juicy 5
REAR DERAILLEUR SRAM X-9, micro cage
SHIFT LEVERS SRAM X-7 Trigger, 9-speed
CASSETTE Shimano HG50, 9-speed, 11-34t
CHAIN SRAM PC-971 with Power Link
CRANKSET Truvativ Holzfeller with Blackspire DS-1 Guide, 170mm
CHAINRINGS 36T, 4 bolt, compact 104mm pattern
BOTTOM BRACKET Truvativ Howitzer XR, oversize sealed outboard cartridge bearing, 73mm shell
PEDALS Alloy platform, 3mm pressed pins, 9/16" Cr-Mo axle
RIMS Mavic EX325 Disc, 26", 36 hole
FRONT HUB Specialized disc, 36 hole, 20mm thru axle
REAR HUB Specialized disc, 36 hole bolt on axle, 135mm spacing
SPOKES 2.0 stainless, black, brass nipples
FRONT TIRE Specialized Chunder 26x2.3" 60 TPI, aramid bead, 2 ply, soft compound
REAR TIRE Specialized Chunder 26x2.3" 60 TPI, aramid bead, 2 ply, soft compound
TUBES Specialized 26x2.75, schraeder valve
SADDLE Specialized freeride light, 8mm hollow Cro-Mo rails with X-Brace, super light foam
SEAT POST Syncros Derived 2-bolt, 30.9x330mm
SEAT BINDER 7050 hard annodized alloy collar with QR, 34.9mm clamp ID, black
NOTES Chain stay/seat stay protector, derailleur protector, Demo tool, reflectors, owners manual
