lawhoo said:
A friend of mine is in the market for a dualie and has settled on the Stump FSR. We ride mostly XC and trail-bike type stuff with a good number of long climbs. He weighs around 190-200. Is the Stump with 100mm of rear travel enough, given weight and sag? Is he better off with the 120mm, even though it will probably bob more on the climbs, etc.?
I have the '05 fsr 100, and I like it a lot! I run about 180-185, and ride pretty much straight XC.
I have two minor complaints - I don't know if they apply to the 120: The BB is low - I'm smacking pedals a lot more than I used to, and; the front end has a tendency to lift off the ground when climbing. I adjusted to it and have learned to use it to my advantage, but you do have to put your weight into the handlebars more than you would normally expect.
If your friend is into slightly more aggressive riding, the 120 wouldn't be a bad idea (it was out of my target price range). Bobbing shouldn't be an issue - the Fox Septune shock has a range of propedal settings, and I expect it has lockout as well.
Either way, your buddy won't be disappointed! The Stumpjumpers are beautiful bikes, and a lot of fun to ride!
P.S.: you might want to crosspost this to the Specialized board.
