Snap poll: What's the lightest bike frame in the Specialized line-up? Has to be one of their road or cyclocross rigs, right? Not anymore. Meet the new Specialized S-Works Epic hardtail, with a claimed frame weight of 845 grams size medium including paint and necessary hardware.
The sub-900-gram frame uses Specialized's top-end FACT 12M carbon. Also note partial external cable routing, which helps keep weight down - and is a lot easier to work on.
But this was not just a grams-shaving project, says Specialized. To hit the ideal balance between stiffness, weight, and strength, they used their top end FACT 12m carbon that's usually reserved for the road side of the line, and used only straight tubes, which are lighter and stronger, but did necessitate the use of a fork bumper on the underside of the downtube.
Sizes run S, M, L, XL, and all tubing and lay-up is frame size specific, which basically means they use just enough material to get the job done for that particular frame size. It all adds up to a ridiculously light finished product. The pictured build with SRAM XX1 Eagle drivetrain, RockShox SID World Cup 29 fork, and Roval carbon wheels comes in at around 18 pounds.
Tires are Specialized Fast Trak with Gripton compound. The rear is 29x2.1, while the front gets some extra rubber at 29x2.3.
Of course, all that light weight will cost you. The SRAM Eagle build runs $8000, while a Shimano Di2 XTR spec'd model will set you back a cool $9500.
But make no mistake, this is a race day bike through and through. The RockShox SID World Cup fork has just 90/100mm of travel and features BRAIN technology, which Specialized claims can distinguish between bumpy terrain and rider input. However, in an effort to keep up with the ever changing (and often rowdier) XC courses of today, Specialized has made some geo tweaks including a roomier front center, longer top tube, shortened head tube, and slacker front end (69.8-degree headtube angle). The S-Works Epic hardtail is also dropper post compatible and features boost hub spacing front and rear.
For more info head over to www.specialized.com.
