Pretty sure it's like BB30 but really wide. 83mm shell?
Not positive but it seems like I remember hearing that you get an adapter to run xtr cranks.
Yes. BB30 works, you just have to extract the bb-91 cups and then go through the process of pressing the bb30 bearings.the mayor said:Ok...it's got a wide shell? Can you use a BB30 crank on it?
Or does it just use Shimano bearing pressed into a big shell?
I have seen a Cannondale Hollogram SL BB30 on a Specialized frame, so I am pretty sure you can run BB30. Plus, Specialized's carbon crank is essentially BB30. They have all the same parts; bearings, circlips, wave washers, and bearing shields. The only issue would be spindle length, but Cannondale and other companies that manufacturer BB30 cranks make spindles long enough to work. I know someone who's Specialized carbon cranks had not come in yet, so he tossed on his Hollogram SL's, they worked perfectly fine.briscoelab said:It won't work with a BB30 crank, so keep that in mind. The shell is too wide. It's Shimano/race race cranks with the adapter cups, or the specialized cranks. I think you can run a Lightning carbon crank, if you get the right spindle spacer though.
not agree ... http://www.bb30standard.com/briscoelab said:That's what I just said.... you can run Cannondale cranks, because the spindle is long enough (now that they use a long spindle on all their bikes.
You can't run normal BB30 MTB cranks on it though, the spindles aren't long enough. For example, you can't run a XX crank, or an FSA BB30 crank. Like wise, you can't run a Specialized MTB crank on another BB30 bike.
Interestingly, Specialized ROAD bikes are true BB30.
Just because they use a bearing with a ID of 30mm doesn't make it BB30.
briscoelab, would you please stop bogarting what your smoking and pass it along!briscoelab said:That's what I just said.... Just because they use a bearing with a ID of 30mm doesn't make it BB30.
Ok-so for BB30 the outer width is about 85mm.eliflap said:instead, the post #4 can help you Nino
that is the width for a BB30 crankset
you have to use Lightning without its cups
adding some spacer with 30mm ID on its spindle, to avoid play of arms
not yet triednino said:By the way - did the Lightning 64/104 spider you ordered fit on that Specialized crank?
